Gearbox Casting Number
Post by r1076 » Sun Jan 29, 2012 4:49 pm
wich is the original ERA gearbox??
Is it DAM5626, Dam4818 or DAM2886 ??
Re: Gearbox Casting Number
Post by r1076 » Sun Feb 05, 2012 8:07 pm
no one an idea???
Post by G96LUE » Sun Feb 05, 2012 10:08 pm
Sorry, No idea here.
Post by kayball » Wed Feb 08, 2012 11:00 am
Some confusion here. heading says "Gearbox Casting Number"
Rest seem to refer to complete gearbox.
from the Microfiche, page E05, my interpretation is that the complete gearbox is " BHM 5161 Transmission Assembly 3.21 final drive." but the casing is BHM 5093 illustrated at E04. Were did you get the DAM numbers?
Post by paul » Wed Feb 08, 2012 3:56 pm
DAM ???? is the number cast on the side of the casing, not the part number applicable to a built unit.
deanojr7
Post by deanojr7 » Wed Feb 08, 2012 4:47 pm
The DAM may possibly be the foundry identification number.
.The foundry normaly put there own part number for there reference and identification as well as the casting number.?
Post by prop » Thu Feb 09, 2012 1:08 pm
I have this copy from a magazine article.
I hope you can read it.
I believe the The A+ 3 bolt main shaft bearing retainer was adopted because the 4 bolt tended to crack with the extra power on the turbo metro cars.
Hope it helps.
Post by r1076 » Sat Feb 18, 2012 4:50 pm
Thank you.
Than it is DAM 5626.
