Ride Hight
Ride Hight
Post by r1076 » Sun Mar 27, 2011 1:22 pm
because I just overhauled the complete suspension and Adjusta Rides fitted (was already installed when i bought the car).
So i need the original ride hight and where it is measured on the front and rear.
Thank you for your help.
Enne
Ian Wheelwright
Re: Ride Hight
Post by Ian Wheelwright » Sun Mar 27, 2011 6:48 pm
Hi I also have HI LO'S fitted as the original ride hight isn't really any good for the car now as the dreaded speed bumps destroy the front of the body kit and you don't want to keep getting that fixed. When mine was rubbed down it was found to have 15 layers of paint how much did that lot cost. Anyway back to the point you really want to set the car so it can be used I think mine is set so you can get 3 fingers between the kit and the tyre good luck.
