Era Cap / Parts?
- mini-haribo
Era Cap / Parts?
hi - i'm looking for the shield that is mounted just next to the oil cooler and the rear sprinkler
- skjold
- c10.png (107.47 KiB) Viewed 41305 times
Re: Era Cap / Parts?
I´m also missing this Duct. I think i will build it myself out of Aluminium.
Maybe someone hase some pics of this part?!?
Isn´t the rear sprinkler the same used on the Metros??
The rear washer jet is the same as a metro one.
I have not seen one for sale for while though.
With regard to the oil cooler duct, i have not seen one come available and i have been looking for years.
I did try making one out of aluminium but it was all guess work and didn't fit very well so gave up.
I have never noticed the oil temp getting high enough to need extra air flow over it.
If someone has photo's of one taken off the car, it would be nice if you could PM some photo's to us 3 and i'm sure something could be fabricated from them.
A MK4 (& maybe MK5) ford fiesta rear washer is similar and might make do if you can't locate a metro one
http://www.ebay.co.uk/itm/Ford-Fiesta-M ... 500wt_1361
The washer jets are used it on the rear of the Landrover defender. The link will take you to Rimmer Bros they are clearing them on a special price at the moment
http://www.rimmerbros.co.uk/Item--i-EAM9332
Oil cooler scoop photos added also
- SANY0070.JPG (42.9 KiB) Viewed 41279 times
- SANY0067.JPG (75.11 KiB) Viewed 41279 times
- SANY0066.JPG (65.55 KiB) Viewed 41279 times
I have a few more photos if you need them.
Please post the pics.
Than everyone who need the part can build one.
Excellent thanks.
The pics are great. I should be able to make one from that.
I see it is riveted to the grill.
I don't suppose you have a pic from the front of the grill you could post.
This will help to show how far it is fitted from the RH grill edge as well as what its riveted too.
I didn't realise it was fixed to the grill as this will make i easier to make and fit.
I might order a couple of washer jets as long term spares before they are gone forever. Thanks for the link
- mini-haribo
Thanks a' lot for all the Replays
